Search for an exact phrase with JQL
30 comments
Akira Higuchi May 7, 2024
@Narsha Bachoo
I tested the following JQL and got the same result.
text ~ "\"SCPR-\""
text ~ "\"SCPR\""
"-" is a special character, so I don't believe it is stored in the index. The documentation for the Data Center clearly states this, but the documentation for the Cloud has lost that mention. I don't know why.
Slava Gefen
and yes I do have scriptrunner installed
@Narsha Bachoo that's great! 👍
In Data Ceneter we could use something like this:
Search syntax for text fields | Jira Software Data Center 9.15 | Atlassian Documentation
summary ~ "SPCR-*"
But it's deprecated in Cloud unfortunately
Search for issues using the text field | Jira Cloud | Atlassian Support
But then you can use this Script Runner Enhanced Search example:
issueFunction in issueFieldMatch("project IN (STAR, SD)", "summary", "^SPCR-*")
That will give you the same result in Cloud.
Here is my example with usual JQL
summary ~ "\"Sub-*\""
That gives all results with "Sub-" even not in the beginning:
And here is the example of Script Runner function
issueFunction in issueFieldMatch("project IN (STAR, SD)", "summary", "^Sub-*")
That gives the desired result:
Documentation is here:
JQL Functions (adaptavist.com)
Hope it helps!
With kind regards
Slava
Narsha Bachoo May 7, 2024
Hi @Akira Higuchi
Thanks but it is not working for me. I am not getting the expected results.
Hi @Slava Gefen
This is working as expected in scriptrunner. Thanks for your help!
Narsha
Like Slava Gefen likes this
Steven Lees-Smith November 13, 2024
This just doesn't work but it is still included in the Atlassian official doco.
The exact phrase match still just seems to work as a wild card search.
summary = "\"This is a test\""
Will return
This is a test
This is another test
Slava Gefen
Something isn't good with your settings, @Steven Lees-Smith .
First of all, this is a mistake
You'll get an error:
But the wildcard with double quotes will give you only one result:
And finally, usual wildcard will give you the result you mentioned:
Hope it helps!
With kind regards
Slava
