It’s not always easy to construct the perfect Jira Query Language (JQL) to filter the issues you’re looking for. Today, we’ll walk through how you can use Atlassian Intelligence and natural language to easily find the issues you need, a few best practices you can use, and even a list of example prompts to get you started!
Atlassian Intelligence allows you to enquire just like you would ask a teammate questions. It translates your question into Jira Query Language (JQL) to find the issues you’re looking for. JQL is a powerful and flexible way to search for your issues in Jira. Through JQL, you can filter your search with the fields available in your project, such as priority, assignee and issue type, combine multiple criteria together, and look for important issues such as the ones that you’re watching or the ones that are blocked.
Check out the demo video that we made to learn how to search for issues using Atlassian Intelligence.
To get the best results, make sure you’re searching for fields and values that exist in your Jira project and include both the fields and values in your search query. You can also specify the Jira project you’re searching in to help narrow down your results.
Read about how you can make the best use of Atlassian Intelligence to search for issues.
Here are a few prompts you could search for and the expected JQL queries to get back. Make sure to replace the project key, label and parent issue key based on values from your project.
Prompt |
JQL Query |
Find issues assigned to me due in March 2024 |
assignee = currentUser() and due >= "2024/03/01" and due < "2024/04/01" |
Find issues in project <project key> created in the last 3 months that are not done yet |
project = "<project key>" AND created >= startOfMonth("-3M") AND statusCategory != "Done" |
Find open issues I’m watching ordered by priority |
statusCategory != Done AND watcher = currentUser order by priority |
Find issues that are missing an assignee |
assignee IS EMPTY |
Find my open issues ordered by earliest due date |
assignee = currentUser() AND resolution is EMPTY order by due asc |
Find the most recently updated stories |
issueType = "story" order by updated desc |
Find issues in project <project key> that are not done yet and blocking another issue |
project = "<project key>" AND statusCategory != "Done" AND issueLinkType = "is blocked by" |
Find epics labeled <label name> |
issueType = "epic" and labels = "<label name>" |
Find unresolved issues ordered by latest created date |
resolution IS EMPTY order by created desc |
Find high priority issues labeled <label name> |
priority = "High" and labels = "<label name>" |
Find issues belonging to parent <parent issue key> that are in the current sprint |
parent = "<parent issue key>" AND sprint in openSprints() |
Find highest priority issues that are being blocked by another issue |
priority = highest and issueLinkType = "is blocked by" |
Atlassian Intelligence is available on Premium and Enterprise plans. Contact your admin to enable these features. How to enable Atlassian Intelligence in your organization.
Shelley Sun
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
0 comments
