Update 23rd October 2023:
Hi all, just an update that these changes to the backlog's epic panel have been rolled out in early October. If you are on the 'Bundled' release tracks, the changes are coming mid-November.
One change that hasn't been mentioned in this post is the removal of "Mark as Done" button on the Epic Panel. With "Epic status" deprecation, that button is no longer needed so it has been removed. To mark an Epic as done, you just need to update the Epic's issue status to the Done category.
Update 27th September 2023:
Hi all, this change will start rolling out this week. As a reminder, you might see different Epics being shown in the Epic Panel / Epic Drop Down, as we are now using the Epic Issue status category instead, and only those that are not marked as Done are listed.
Hi Jira Community! đź‘‹
We announced last year that we’re making changes to epic fields in company-managed projects.
As part of these changes, we highlighted that epic status will no longer be used and we will use an epic’s Issue status category instead to determine whether an epic will be displayed on the backlog’s epic panel.
[Updated 4th August 2023] This change will happen end of September 2023.
Continue reading to learn how these changes might impact you and what you can do to prepare.
Previously, the backlog’s epic panel used an epic’s Epic status value to determine whether an epic would be displayed. By default, the Epic status is only accessible from the epic panel, otherwise admins had to configure a field for it to be visible in the issue view.
Additionally, epics that were marked as Done were hidden from the epic panel list, regardless of the status of their child issues.
We’ve changed the logic of the epic panel slightly to respect the epic’s Issue status category instead. If you've created custom statuses in the Done category, the epic panel will behave as if the epic was complete if it is using one of these statuses.
If you have epics whose Epic status is marked as Done but the epic’s Issue status category is not Done, these epics will re-appear on your backlog epic panel.
If you have epics whose Epic status is not Done but the epic’s Issue status category is Done, these epics will disappear from your backlog epic panel if all of its child issues are also marked as Done. [Update - 04 Oct 23] The child issues don't all have to be marked as Done for epics to disappear from your backlog.
We’ve provided a couple of JQL scripts for you to identify any Epics that have a different Epic status to their Issue status category. You can then use Jira’s bulk change functionality to update these statuses to match.
[Updated 4th August 2023] Our rollout begins in August end of September 2023, so you’ll have until early September 2023 to review your epics.
To view the epics that will appear in the epic panel once this change rolls out, use the following JQL in Advanced Search:
"Epic Status" = "Done" and statusCategory in ("To Do","In Progress")
To view the epics which may disappear from the epic panel once this change rolls out, use the following JQL in Advanced Search:
"Epic Status" != "Done" and statusCategory in ("Done")
[Updated 4th August 2023] We'll begin progressively rolling out these updates from the end of September 2023.
Keep an eye out here on the Atlassian Community for more information as we get closer to release.
In the meantime, if you have any questions or feedback on these updates, let us know in the comments below. Thanks all!
Irene
Principal Product Manager
Atlassian
Sydney, Australia
7 accepted answers
56 comments
