Sign up Log in
We're bringing updates to the issue navigator
Hi everyone,
We’re excited to bring highly requested features to Jira Cloud’s issue navigator, and upgrade your experience when you search for issues.
Column Configuration
Select fields to show them as columns in list view using the column configuration menu.
Reorder your columns by simply dragging and dropping the header to its position. You can configure your columns and order them as per your preference to make the configuration your own.
More fields for your criteria
Refine your search criteria with more fields like label, fix version, component and parent. You can also use these fields as columns.
What's next?
This new search experience is available only from a project (go to your Project > Issues) for Jira Cloud.
Note: If you’re in a team-managed project, you’ll have to enable the issue navigator.
We’ll be broadening this so you can search for issues across all projects in the instance. We’ll add support to more fields in the More+ menu and column configuration in list view, and improve the Export feature.
We’re keen to hear your feedback and suggestions to improve searching for issues in Jira Cloud.
3 comments
Yatish Madhav
February 27, 2023
Thanks for this @Kevin Yu  - I first wonder what is the actual improvemennt here then realised the column order change was not available before. Thanks for this, it is an improvement that will help I am sure.
Question - if the columns and order is changed on a project issues navigator, is it shown the same for everyone or is it a personal configuration?
Like Dave Mathijs likes this
Jordan Koukides
February 27, 2023
Thanks for the comment @Yatish Madhav. At the moment it is a personal configuration but we will be adding support for configurations that can be set by admins or within the scope of filters in the near future.
Like Yatish Madhav likes this
Yatish Madhav
February 27, 2023
Thanks for the quick reply, @Jordan Koukides - great, happy with that!
Register Now
Upcoming Jira Events
