Ability to Include Swim Lane in Software Filter Export
Jason Spellman
Is there a method to include the swim lane for a filter export for a software project? I believe this would be very beneficial for reporting.
Trudy Claspill
Hello @Jason Spellman
Can you clarify what you mean by "swimlane"? Perhaps provide some screen images to illustrate your example.
A Swimlane is a setting in an agile board, not in a project. I am unclear how you would anticipate that being included in the exported results of a filter.
Jason Spellman
Yes with in an agile project, if they are assigned to a swimlane I am wanting to capture the issues associated with each swim lane. So if Swim Lane named Selected for Development and I had 4 issues in that lane I want to be able to export the issues that show the Selected for Development swim lane.
Like • John_Alvin likes this
Trudy Claspill
Thank you for that additional information. I think I may still not be understanding your request. If you could provide a screen image that shows an example of your swimlane that would be helpful.
"Selected for Development" sounds like an issue status to me, which would be displayed in a column (vertical grouping) rather than a swimlane (horizontal grouping) on a board. I'd like to make sure we're talking about the same type of grouping so I don't provide a misleading answer.
Jason Spellman
Jason Spellman
When exported I want to see the issues associated with each and labeled accordingly.
Trudy Claspill
Thank you, that clears it up.
The definition of Swimlanes is a per board setting, not a project setting.
In your board, how have you configured the Swimlanes?
Also, are you working with a Company Managed or a Team Managed project? That information will display in at the bottom of the panel that displays on the left.
Jason Spellman
Company Managed Project. I want the swim lanes to appear with the work that is associated with them.
Trudy Claspill
In your board how have you defined the swimlanes?
What is shown under Board Settings > Swimlanes?
