Acceptance Criteria (Done When) - when adding stories, where is the best place to add the Acceptance Criteria for the Story?
Thank you,
Winn
Community moderators have prevented the ability to post new answers.
or you may add a customfield (Text) to the Screen
You may also want to check out a JIRA add-on called Checklist. It is perfectly suited for Acceptance Criteria
Doesn't seem to work for OnDemand. :( Any ideas?
Unfortunately, Checklist isn't available for OnDemand customers and I am not aware of other solutions that meet these requirements and that are OnDemand friendly.
I was adding them in the description and that worked as an alternative. However, as other things were added the AC got lost a little (or hard to find). A Custom Field did work - I did not have access to create a custom field but the Admin did. We are off and running - thank you!
