Access permission based on Component
Bala Krishna
Pl help me on how to Achive this.
Part I.
I have two components in one project.
1. Loan
2. CRM
I have two diff set of groups in that projects. each contains many members. I am unable to restrict users based on Component.
we want to assign one component to one group.. and we dont want others can view/browse other component issues (any thing Bug/Enhancement).
Part II.
our Jira is integrated with GreenHopper.
We created two Kanban Boards based on Component field value in the filter.
We also want to restrict groups there are not part of that component.
like Group 1 has access to Loan so they should see only Loan Board
Group 2 has access to CRM so they should see only CRM Board
pl advise.
Thanks in Advance,
-Bala
Nic Brough -Adaptavist-
October 29, 2012
You can't do it directly. There are no permissions for components.
Indirectly, you could try to find or write a plugin that will set a security level based on components.
But you've said you're using "OnDemand", so you can't install anything.
Bala Krishna
hmm okay thanks Nic.
Norman Abramovitz
October 29, 2012
I am a bit confused on your example. You have two components. You have two groups. One component will get one group and the other component will get the other group. Each group cannot see what the other group is working on. A user could belong to both groups and they can see everything.
If my understanding is correct, then I would have two projects corresponding to your two components instead of one project with two components to deal with your security issues.
Bala Krishna
Well, one group is own team other group is Consultants so our management wanted to work them that way. I like your idea, but our management dont want to have two diff projects.
we have only two guys (managment level) working for both components. so if seperation is possiable then we can assign both of them to both components.
-Bala
Norman Abramovitz
October 30, 2012
As Nic has stated already, the OnDemand version does not have that freedom to modify Jira to your requirements at this current stage, but it does have the functionality as described in your question.
Wiithout getting into your company's politics, do not get hung up on the Jira's terminology. A project defines how a set of individuals interact together for a common goal. The level of protection you are asking for is built into Jira which is labeled as a project. Does it really matter if your issue key is called CRM-1234 or Loan-1235 verses (proj-1234 and proj-1235) Look at the list of 'projects' that Atlassian defines:
https://ecosystem.atlassian.net/secure/BrowseProjects.jspa#all
Many of these projects are used across multiple products. Use Jira's concept of a project to meet your needs.
One of the few nice things about the new boards, they do work across projects. There are multiple reasons why the boards work across projects and your type of requirements is one of them.
You could even have a third project that mananagement uses that combines the two other projects for their planning purposes which they only see.
So, given the information in your question, a solution is possible with Jira OnDemand.
Bala Krishna
I tried with adding security level field in issues. But would like to see based on Component field
Maxim Abramovich
Yes, use two security level ans write post-function, wich set level according selected component.
Michelle Gronwold
How would you do this?
Get Certified! ✍️
