I need to auto generate a ticket with a table in it. One column needs to be accessible to add a date. I cannot figure out how to get the table in the description of the auto generated ticket and allow the date column to be accessible.
Example:
What method are you using to automatically generate the issue? API? Automation for Jira? CSV import?
Can you expand on what you mean by "once column needs to be accessible"? At what point does that column need to be accessible for adding values? After the issue is created then the Description field should be editable and values should be able to be entered. If the values are known when the automation is run, they could be included in the table at the outset.
Have you been successful in adding table-formatted information to the Description field while creating the issue via automation, or are you also trying to figure out how to do that?
