Activity Stream Filter by Project
Jose Antonio Quesada January 23, 2023
I've a large team with a lot of projects.
I want to filter the Activity Stream so that each user can see those projects in which he/she has a ticket assigned to him/her.
I don't want them to see projects they are not working on.
Could you help me?
Jose
John Funk
January 23, 2023
Hi Jose,
You can create the filter first and then use the filter in the Activity Stream gadget.
Jose Antonio Quesada January 24, 2023
Hi John,
This is my problem, I don't know how to create a filter with these condition:
"Show me only projects tickets where at least one ticket is assigned to me"
John Funk
January 24, 2023
Okay, I see now. But that is different from an Activity Stream. And Activity Stream shows every transaction that has happened on a project or been performed by a user.
You are just looking for list of projects where you have a task correct?
If so try this query:
assignee = currentUser() and statusCategory != Done
That will show for each user when they look at it.
Then create a dashboard and add a gadget for Issue Statistics. Then select Project for the Statistic Type. See if that works for you mi amigo.
Jose Antonio Quesada January 25, 2023
Not exactly. I want to use Activity Stream because I want users to see the news about the projects they're involved.
Right now Activity Stream shows all the projects, and it's not we need.
John Funk
January 25, 2023
You would need a different Activity Stream gadget for each project. You can't dynamically change the project in the Activity Stream gadget. If the user has access to the project, they will see it.
Oooohhhh!! I thought so. Thank you very much for your contributions.
BR
Jose
Like John Funk likes this
John Funk
January 25, 2023
You are very welcome.  :-)
Marlene Kegel - codefortynine
Hi @Jose Antonio Quesada,
I am Marlene from codefortynine.
If you need to filter the Activity Stream gadget dynamically, you can check out our app Quick Filters for Jira Dashboards.
With our app you can add a "Quick Controller" to your Jira dashboards to filter the results of your gadgets. You can check out how our app work without installation on our demo dashboards.
FREE
