Add Hyperlink to Text in E-mail Automation
Oliver Skelton January 30, 2025
Hi there,
I have an e-mail automation set up that sends a list of items out each week based on an issue filter.
Rather than just paste the raw filet into the body of the e-mail, i would like to add a hyperlink to a word in the text like for example " Issues can be viewed Here" the used clicks on here and is directed to the list of issues.
Does anyone have any ideas?
Thanks.
Oliver.
Vishal Biyani
January 30, 2025 edited
@Oliver Skelton
Assuming you have the filter link use below in the mail body
Issues can be viewed <a href= https://your-instance.atlassian.net/issues/?filter=10102>Here</a>
Perfect, thanks Vishal!
Marc - Devoteam
January 30, 2025
HI @Oliver Skelton
You will need to use HTML formatting for a URL in the email action in the automation rule.
Example:
<a href="{{issue.url.customer}"><b>survey</b></a>
Thanks Marc for your response but what if i don't have a smart value for the Issue filter?
So the Url is https://community.atlassian.com/t5/Jira-questions/Add-Hyperlink-to-Text-in-E-mail-Automation/qaq-p/2930899#M1085549
But I want to just have the hyperlinked word 'support'
Possible?
Marc - Devoteam
January 30, 2025
