Add Parent limitations in Jira NexGen
hromero November 7, 2019
Is any way to "add parent" other than an Epic ? for instance I want to create this hierarchy
Epic-> Feature-> Story-> Task, but the limitations of Jira NexGen don't let me do it , if this is going to target an agile audience it should be flexible enough to allow any kind of hierarchies
Pete Singleton
November 7, 2019
Unfortunately this isn't available using standard Jira Software.  However, you can define a hierarchy using Portfolio for Jira or the BigPicture addons.
Thanks for your reply. I am assuming when you mentioned "standard jira" you are talking about the NexGen version correct. Also do you know if Portfolio for Jira is something available for NextGen or an add-on feature ?
Pete Singleton
November 7, 2019
NextGen is a project type in the Cloud version of Jira.  Regardless of whether you are using nextgen projects or standard projects, you will need an add-on.  Either of the two I mentioned will work.
Got it! thank you
