×I am having an issue collector with different fields. I want to add a bundled field to it but am unable to find any guide for it. I have tried adding it using the custom fields method but no luck. Is there any way I could add it using javascript or something?
Here is my bundled field
Hello @Jamshaid ,
Thanks for reaching out to the community.
The Text field and the Date Picker should have no issue being added to a customs issue collector but there are some custom field types that can not be displayed in Issue collectors since they cannot be displayed to anonymous users, and the user picker field falls into this category.
There is no way to add a user picker to an issue collector as it required a user to log in to be granted browse user permissions to access the user management system to see the values presented in the field, and can only be accessed locally. Since the issue collector is triggered from an external system it cannot pass the login credentials to access the field types requirements for access to the field data.
This is covered in more detail in the Documentation "Use the issue collector" noting The fields types that can be displayed in an issue collector are:
Earl
Hi @E M ,
Is it possible to have prepopulated table within description as field values for Issue Collectoe?
