Currently we have created a field called Story point and when a card is created in jira type improvement, bug, HF and task, it does not allow to put the points, that field only has the user stories
the idea is to put it on all the projects in jira and make it visible
Hi Juan Carlos,
If you created that field, go check the Context to be sure all of those issue types are available for the field.
Go to Settings > Issues > Custom Fields
Search for the Story Points field, then click the 3 dots menu to the right and select Contexts and default value.
