Adding Epic Statuses
Mark Grenville August 14, 2020
Is it possible to add Epic statuses for next gen projects?
Ste Wright
August 15, 2020 edited
Hi @Mark Grenville
All issue types in Next-Gen products share the same workflow at this stage - so whatever workflow is configured on the board will also be shared with Epics.
If you are referring to the drop-down filter "Status" in the Roadmap view - which includes To Do, In Progress and Done - this is just filtering on status category. IE "To Do" is the first status on a board, "Done" is the last status and "In Progress" is all statuses inbetween.
This might change in the near future though. See the public roadmap - Reimagining the Workflow Editor.
Specifically, see this quote:
In next-gen, workflows live within projects and will be tied to specific issue types. So for example you could have a specific workflow for your bugs and another workflow for your stories.
You can also follow this specific feature's progress in JSWCLOUD-17434
Ste
FREE
