Adding Issue linking item - team managed vs company managed impact
Jenny Finneran
One of my teams would like to add "depends on" and "dependent of" as issue linking options. The teams already have the issue linking permissions they need to see this change once implemented.
We have both team managed projects and company managed projects.
The team requesting this is team managed project, but I don't see a way to differentiate as to which project types will be impacted.
If I make this change, will it apply to both team and company managed projects? Or only team managed projects?
Please advise.
Trudy Claspill
Hello @Jenny Finneran
The Issue Linking types are global. All link types are available in all projects; both Team Managed and Company Managed.
Yi Meng
Hi @Trudy Claspill
It seems that there is no issue linking for team-managed projects. There is only parent-child relationship such as story/sub-task, or Epic/story.
If you click the 'add' button, there is no linked issue option.
Trudy Claspill
Hello @Yi Meng
Issue linking is a feature that is available in Team Managed projects. You may not have permission to use that feature.
Please click on the Ask a question option in the blue menu bar at the top of this screen to start your own new Question to get additional assistance with your problem. If you think this post is relevant, include a link to it in your new post.
  1. This post already has an accepted answer. If the solution doesn't work for you, you should open your own Question to get help debugging that.
  2. The only people that see updates on posts are the original author, people watching the post, and responders to the post. Subsequently your update currently is not being seen by a very wide Community audience.
  3. Adding to an old post without adding value to the post is referred to as "necroposting" and is considered poor community etiquette.
Read the story
