I have multiple stake holders who want to see where there items are falling into the backlog. Without reading all the stories and tasks this is hard. I found the JIRA linke here where you can see Epic fields, so I'm assuming this is possible somewhere??? If not I'd be happy just using the Epic fields, but cannot figure out how to get that to show.
https://jira.atlassian.com/secure/RapidBoard.jspa?rapidView=96&view=planning
Any help would be great!
Hi there,
From your inquiry, I understand that you would like to add a custom field into the issues detail view in the Scrum board. If this is true, then I believe that you can add custom fields to the view as follows:
- Open the board
- Open the Tools drop down > Select Configure
- Open the Issue Detail View tab
- Try to add the custom field in question to the view
Hope this helps!
Cheers.
I'm looking to add the field on Greenhopper 6.0 > Agile Scrum Board > Plan Tab. Right now it's only showing Card Type, Priority, Card #, Description, and Estimate. I want to add Requesting Group a field that I've added. In the classic version I could choose which fields to add or hide on the "List View", but with Greenhopper 6.0 I cannot find the spot to tdo this.
I am wondering whether this is currently possible. We would like to add the created custom field "Business value" to the plan mode to help us planning. Unfortunately I don't see an answer to the question of EMU_FLYER
Thanks Ahmad...your answer helped me
Hmm, they've updated the interface. I cannot find it again. ;-//
Seems like the application is not very configuration user-friendly...
Would anyone be able to advise the new instructions based on the new UI?
Yes, this opportunity would be great, because fields like component are important for the users!
+1
I'd like to be able to:
- Add custom fields of type dropdown to the Issue Detail View. As of 6.0.5 you can only add types text and number.
- Customize the fields that appear on the cards, in plan and work mode, like you can do on the Classic Boards.
