Hi - how can I add an additional field into the backlog-view of a project? Actual there are 9 fields to enable, but e.g. the field "Reporter" is missing in the list of view settings. I would like to add that, so it is displayed in Backlog-board / Scrum-board etc.
Thanks for your help !
Hello @Christian Mooser
What type of project are you using? Get that information from the Type column on the View all projects page under the Projects menu.
If you are working with a Company Managed Software project then you can add up to three fields to the Card Layout in both the Backlog view and Board view separately.
https://support.atlassian.com/jira-software-cloud/docs/customize-cards/
This feature is not available for Team Managed Software Projects but there is a change request for it.
