To be honest, Atlassian is frustrating. There is no way to contact support or put in a ticket. I have been going all over the web for 3 hours now.
I am an admin and I need to remove or revoke another admin that left. So many people have same issue and no where on the web is a solution. At least make it easy for someone to contact Support. I wish we could move away from this software.
Hi @Ekene Awuzie ,
I‘m sorry to hear your frustration.
In order to remove an admin, this help article might help you. It basically tells you that you need to remove the admin from the user management in your organization administration on admin.atlassian.com.
If you still need help, you can further try to get help here from fellow users or contact Atlassian support via this url.
I hope, you can solve your problem quickly.
Matthias
Regards, Roman
