How do we get Advanced Roadmap or Portfolio activated for trial version to start so we know whether it meets our req or not?
Basically I am looking for something where I can tag dependencies in Multi Scrum team and multi project environment
Hi @Peyush Agarwal ,
Portfolio for Jira Cloud is now known as Advanced Roadmaps. You can trial it today as part of the Jira Software Premium Feature.
Link: https://www.atlassian.com/software/jira/premium
Further info check out Cloud Pricing FAQ: https://www.atlassian.com/software/jira/features/roadmaps/pricing
Kevin.
Where can I check if my license if Premium or Standard?
I think its Premium because I can do automation globally if yes then being Premium account holder why I dont see this feature enabled?
To check if the licensing is premium.
Setting -> Billing -> Manage Subscription
To Find Advanced Roadmap.
You can click the Plans menu option in the top navigation bar.
I have also attached an image for your reference.
