Advance Velocity Report
Dexter de Vera
Hi All,
I would like to ask Plug-In that can modified the velocity chart.
e.i Workflow: To Do - In Progress - Review - Done
In velocity chart the commitment are base on all ticket while Completed are the Done status.
Would like to modified the Completed to Review not Done Status.
2 accepted
Danut M [StonikByte]
Hi @Dexter de Vera,
You can easily do this by using the Team Velocity gadget offered by our Great Gadgets app.
This gadget has an option that allows to specify what statuses to consider as Done / Completed.
This app offers many other useful gadgets for Scrum, Kanban, SAFe, etc. It can be a great asset for your company. Have a look over our blog to make an idea.
I hope this helps. If you have any questions, please contact support@stonikbyte.com.
Danut.
Dexter de Vera
Thank you @Danut M [StonikByte]
Trudy Claspill
Hello @Dexter de Vera
The Completed tickets are based on the issues in the column farthest to the right on your board, regardless of what Statuses you have mapped to that column.
If you map the Review status to the column farthest to the right, then the Velocity chart will consider those issues Completed.
Note though, that the closing of a sprint will also consider the issues Completed, and they will not be moved to the backlog or another sprint.
There is not an app that will modify the built-in Velocity report, but there are apps that give you alternate Velocity reports. You can review those to see if they also give you the ability to customize the definition of Completed issues.
https://marketplace.atlassian.com/search?hosting=cloud&product=jira&query=velocity
Dexter de Vera
Thank you @Trudy Claspill
