Advanced Roadmaps Teams field
Anastasia Gourina October 27, 2021
Hi all!
Not sure if this has been asked before but I have come across interesting statement regarding Advance roadmaps and the Teams field.
"Tip: The teams field in Advanced Roadmaps is not visible by default in Jira Software. For a seamless planning experience, enable the teams field to display in the Jira Software project you’ve used as an issue source."
I have been trying to figure out how to enable this in Jira software and had no luck. Can anyone guide me on how I can do this?
Thanks in advance!
Robert Wen_Cprime_
So, for all the Jira projects that are sources for Advanced Roadmaps, you need to make sure that the Teams field is on the screens for the issue types you view in Advanced Roadmaps.  Instructions for doing this are here: https://support.atlassian.com/jira-software-cloud/docs/enable-custom-fields-used-in-advanced-roadmaps-in-jira/
Learn more
