Advanced Roadmaps - enable epics progress bar
Ben Werner April 27, 2021
For some reason I don't see a progress bar under my epics in Advanced Roadmaps. Can anyone explain to me how to enable this?
Thank you -
David Wuth
April 27, 2021
In the plan, you add (or remove) the progress field(s) just as you would any other fields. There are two progress fields: Progress by story points and progress by issue count.
Ah - it's under "fields" - thanks David!
Like • 2 people like this
raluca.teodoru
July 13, 2023
How can I find the ID of the two progress fields: Progress by story points and progress by issue count? Thanks!
Register today
