I'm pretty sure that my project meet all the criteria to bne able to switch a board simplified workflow:
Still, I Keep getting the "Agile Simplified Workflow unavailable". I don't know what else to check.
Ideas?
Hello Claudio,
Based on the description that you've mentioned, it looks like you're running into a bug, though a fairly minor one.
Basically, one of the requirements is "That project uses a JIRA workflow scheme which only has one workflow for all issue types". The bug is that this "assumes" that you didn't individually assign the same workflow to all issue types.
So in this case, to fix this, you'll want to basically:
* Edit the Workflow Scheme
* Remove all the assigned Issue Types (that is, click the "x" next to each issue type)
* Do this for all issue types, leave just "All Unassigned Issue Types"
* Click Publish
This is a bug, as JIRA should be able to respect your original setup. For you reference, please see GHS-8720.
Hope I was able to help you.
Monique
It would be good if this workaround was attached on https://confluence.atlassian.com/display/AGILE/Using+JIRA+Agile+Simplified+Workflow?src=search#UsingJIRAAgileSimplifiedWorkflow-whyNot.
I just spend an hour going through all criteria, being lost and frustrated because of this issue which I could not have known was blocking this.
I agree. The documentation is lacking. And besides, there should be some kind of diagnostic tool to help with this, it's terribly aggravating to poke in the dark like the current system requires you to do.
Good job u can use the default jira workflow
2020 v8.blah and it is still a bug.
We were seeing this problem today.
The problem was that the project had been re-named, and the Filter was incorrect. We fixed the filter, and we were able to assign the simplified workflow.
2021 and I still want to jab my eyes out with very pointy sticks. I agree with the need for better documentation!
Thanks Veracode NOC, I faced the same issue and your pointer helped to solve it.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
