We are planning to migrate from Server to Cloud by the end of this month and one of the required Apps is 'Q Collapse for Jira Service Management' that it's not available on Cloud.
Are there any options similar to this one for Cloud?
Hi @Daniel Alonso ,
don't think the functionality is exactly the same but maybe you can fill the gap with Queues for JSM (Deviniti) ?
It allows you to create Queues (cross project) and hide/show them and also add them in folders.
Thanks for your response Dirk,
Yeah, it's a good alternative. I will check it out and review with the customer and back with the results.
Hi @Daniel Alonso , did you get the same functionality for queue collapse with with Queues for JSM (Deviniti)?
Hi Jeno,
Yes, the add-on has the collapse functionality, but it has it only for one level right now.
