Any way (even with addon) to show points AND hours on cards in sprint and backlog?
Phil
Hi Community,
We use points as our unit of estimation and for communication with our end-users, but internally it is critical that we observe time-logged vs original-estimate.
We just switched out boards to use original-estimate as the unit of estimation, but ideally my team needs to see both at the same time.
Can it be done?
2 accepted
Trudy Claspill
Hello @Phil
Are you working with issues in a Company Managed project or a Team Managed project?
If you are working with issues in a Company Managed project, you can modify the card layout to display the other data fields.
Here is an example where Story Points is the Estimation Statistic, and Original Estimate and Time Spent have been added to the Card Layout.
Phil
Can't believe I missed that! Thanks!
Magdalena Zhisheva
February 3, 2023
Hi @Phil ,
You may try to go to the project, open the board and go to Board settings -> Card layout and put all fields you want to see on the Board cards.
Hope it helps!
Phil
Thanks! Can't believe I missed that.
Like • Magdalena Zhisheva likes this
