We are integrating with Mend and the automated creation of issue is using Task type. We aim to use a Different Jira Type to easily distinguish the vulnerability. Any opportunity to change the default automated Jira type?
Having security and the integration to other apps is cool and great btw! We've been looking for this.
Hi @Donny Gison
I'm not familiar with Mend, so I have to ask. How do you create issues in Jira automatically? If you use any tool or some scripting, there you have to find some configuration.
I see in our integration with Snyk that I have option to Create issue from this page, so when I'm clicking on this button, the Create issue dialog opens. So I can easily select in which project with which issue type the new issue is created.
As in your company it has been done automatically, I guess you should check any configuration where this automation is set.
~Kate
