Quick filters are a really useful tool in Scrum and Agile boards, but I get confusion from my users. For example out issues go through several distinct periods, PM, Dev, QA, Done. I have quick filters for each of these, but the work as "AND" buttons. if I want to filter on Dev & QA, I have to create a new filter.
Is there a way to "OR" the filters, so I can click on two filters and get the "OR"ed result?
No, the filters are deliberately set as AND, and they do try to show you that they are selected many times. I suspect that with a bit of code (possibly even just javascript), you could change the behaviour so that when you click one filter, it automatically deselects the rest (although you're then going to find people like me who need AND in there complaining)
Note, you've said OnDemand, so your only route is javascript, as you can't hack the core code.
Is there a feature request ticket in JIRA that we can vote on and follow?
Atlassian have pretty much said "no". See https://jira.atlassian.com/browse/GHS-8975
I would love to be able to configure filters to be grouped mutually exclusive, like radio buttons. The UI should be displayed as a group of buttons, (e.g.: http://getbootstrap.com/components/#btn-groups )
You would define a group by adding a group (displayed as a drop area) in the quick filters option, and then dragging the filters into that group.
The only use that is requested regarding this OR operation is people want to see certain issues plus anything else that is assigned to them. For example, the "me + unassigned", we made that into a single quick filter. But the frontenders like "my + label:styling", JS specialists "me + label:js", etc. We could of course make quick filters for that but the list is getting quite long. So if the "OR assigned to me" would be a separate option next to the quick filters that would be helpful
Per Nick's suggestion to wrap in some custom JavaScript, if you have a tool like TaperMonkey that can run scripts on top of any site, then you can enable single selections by default by adding the following code:
$("body").on("mousedown", ".js-quickfilter-button", function (e) {
// if de-selecting, don't do anything
if ($(this).is(".ghx-active")) return;
// if holding down ctrl or shift, allow click
if (e.ctrlKey || e.shiftKey) return;
// otherwise, active click on any active elements to deselect them
$(".js-quickfilter-button.ghx-active").click();
You can install the script from openusersjs.org or view it on GitHub
It seems like whenever there's a feature we're interested in, Atlasssian either said "no" several years ago or is actively removing from the new version of the app. :-(
In the current version you can simply switch to "JQL" query then change AND to OR including parenthesis if necessary.
I found a solution to the problem.
It is necessary to use inverse logic.
For example, you have three projects: P1, P2, P3.
And you want to display issues from these projects in different combinations.
You need to create three quick filters:
JQL: project != "P1"
JQL: project != "P2"
JQL: project != "P3"
Now, by switching these filters, you can choose any variation of the project mapping:
P1 + P2 + P3
P1 + P2
P1 + P3
P2 + P3
P1
P2
P3
Yep, I am finally using the same approach. But still it is not so clear for end users.
Good workaround.
You can then create a view / shortcut where all quick-filters are selected, and de-select from there as appropriate in meetings...
Using this. Glad I found it. Thanks!
One of the ways to display and/or filters might be to have panels: buttons within a single panel enforce OR conditions, and filters checked in different panels enforce AND conditions. That would be just perfect from my point of view and should be quite user friendly and clear.
Migrate to server afterwards you'll be able to filter the board without any limitations using the Agile Board FIlter add-on
Cheers
Przemyslaw
Create a dashboard based on the filter "PM & Dev & QA & Done", and quick filters to exclude each one.
I am actually running into the exact problem. I have a need to display 1 OR many projects issues based off a label. When I select multiple projects, it uses the logical operator of "and" instead of "or" and immediately displays 0 results (since an issue can only be to 1 project). I understand the logic of "and", and agree it should still exist. Having the option to create "or" filters would be a huge help.
Correct, you can't have it both ways, and AND is *far* more useful choice when you can't. It would be nice to be able to use OR instead, but you'd need a *very* clear way to display it.
I also would like this feature, but unlike the user below is implying it's not from confusion of users but rather a desired function to combine to filtered groups.
