Association With
sarathgd
I have a project with 'System Change' as issue types as part of the project.
Few of the system changes are added as child entries to one system changes with 'Associated With' option ( 1 to many )
Ex: System Change 11 --> Associated With --> System Change 22 & System Change 33.
I tried to build a structure with automation >> Extend >> Linked Issues >>Associated bugs & Stories >>Associated with, but I am getting 'generator' error,
Appreciate any help here.
Thanks in advance,
Sarat
David Niro
Hi @Jack Brickey, I believe @sarathgd  is using Structure by Tempo.
@sarathgd , if I have that right, it is most likely due to where you are trying to add the Generator (automation).  Please try selecting the name of your structure (just under the summary column header) and once selected, add your Extend Generator.
Please let me know if it helps!
Best,
David
Jack Brickey
January 5, 2023
Hi @sarathgd , I am not fully following. Please provide your Automation rule and audit log.
FREE
