Atlassian connect app is not opening in Jira
Jira May 12, 2023
I have created an app using ACE and deployed to Jira using ngrok. The app is installed in Jira but not opening.
I have referred the following blog
https://developer.atlassian.com/cloud/jira/platform/getting-started-with-connect/
P V
October 15, 2023
I am facing the same issue. If you figured out the issue, please comment the way you fixed it.
Thanks in advance.
FREE
