Attachment requirement validator
Dorothy Callahan
Hi all,
I want to requirement attachment when issue is created.  I have added a validator to "Create" transition that requires attachment however, even when I attachment is uploaded, I continue to receive message stating attachment is required.  Transition_ Create_Attachment Validator 20230815.pngAttachment requirement warning 20230815.png
Mayura Gautham
August 15, 2023
Hey @Dorothy Callahan
Good day!
Please note that Forms and attachments are different entities in Jira. In order to make attachments mandatory while creating issues, you need to add the Field Required Validator and choose Attachment.
Screenshot 2023-08-15 at 10.45.28 PM.pngScreenshot 2023-08-15 at 10.45.40 PM.png
Once done, please make sure to remove the Forms validator.
Please make sure to accept this answer if it helps :) And of course do let me know if you have any more questions.
Dorothy Callahan
Perfect!  It worked!  Thanks so much!
Like Mayura Gautham likes this
Antonio Calì
the same issue, validation for Attachment doesn't work
amit.bakst
Hi @Mayura Gautham ,
I tried to implement the solution you provided in Jira, but it seems that Jira was unable to validate the attachment.
I have attached a file to the ticket and set a validator for this transition.
However, I received an error comment.
Can you please help me resolve this issue?
Thank you in advance.
Amit
Sandy Huanco
November 13, 2024
Hi Amit, I have the same issue... did you manage to solve it?
Maciej Dudziak _Forgappify_
Hi @Sandy Huanco
The Field Required Validator, available out-of-the-box in Jira, ensures that fields are not empty during a transition, including Create issue transition. However, it only works when a transition screen is present.
For example, if you added an attachment on the issue view and then tried to change the status, the validator ignores previously attached files and expects a new file to be added during the transition. Without a transition screen that includes the Attachment field, the validator will block the transition.
You have two options: either add a screen with the Attachment field to your transition, or—if that’s not ideal—consider using a third-party validator.
At Forgappify, we developed the Fields Required Validator (WBB), which is part of the Workflow Building Blocks for Jira app. It checks the state of the issue during the transition and will pass if an attachment has already been added.
I hope it will help.
Cheers
