Hi everyone,
Working with JMWE, I've created a post function that creates a new issue and copies some fields to it, including the attachment field. while all attachments are successfully copied, any reference to them in a wiki rendered field is broken (see attached screenshots).
how can I fix the references? is there another field that needs to be copied other than the attachment?
unfortunately, this is a bug in Jira Cloud. My bet is that, if you go to the "old issue view", the inline images will work. Did you try?
thanks, you're right. the old view seems to be working better in this case. is there an open issue to vote on?
I couldn't find the bug so I created a new one: https://ecosystem.atlassian.net/browse/ACJIRA-2175
