Attatching a Form to a Task
scherdin
Hey, im trying to create a Automation that copy's a attatched Form to a different Ticket.
2024-08-15 13_15_50-[ITH-5117] Test - Jira.png 2024-08-15 13_16_19-Audit log - Automation - IT Hilfe - Jira.png
But for some reason, it just doesn't seem to work no matter what i do.
Kind regards
Marc - Devoteam
August 15, 2024
Hi @scherdin
I read the conversation.
There is a special edit action for forms, "Copy Forms".
Use this action.
scherdin
Hello @Marc - Devoteam
I can't find the option, where can i find it?
Marc - Devoteam
August 15, 2024
Hi @scherdin
This is only for JSM related issues, as @Jack Brickey  mentioned.
I missed the point that you linked issue wil be in a non JSM project.
scherdin
Alright, thanks regardless.
Like • Marc - Devoteam likes this
Jack Brickey
Hi @scherdin , are you copying an attachment from one issue to another? Are you copying from the trigger issue? Can you share the Edit issue fields configuration?
scherdin
Yeah sure, this is the edit issue field.
scherdin
Its also a dynamic form that we use for onboarding processes. Ive read something about them not being able to be copied but i may be mistaken.
Jack Brickey
Thanks. Are you sure the trigger issue has an attachment? What does the audit log show?
scherdin
The edit says, Issue edited successfully. But the form doesnt show up.
Jack Brickey
Dynamic form? Wait is this an actual attachment or is this JSM or JWM "Forms"?
scherdin
Im also trying to copy the form into a different project that is not a service project. Is that maybe the problem?
scherdin
Its a form that people can fill out for our onboarding process to send us the requirement. Unfortunately i dont know which one it is, but its just a simple form you can create inside of Jira.2024-08-15 13_54_37-IT Hilfe - Forms - Service project - Jira.png
Jack Brickey
I see, no that is not possible. It seems the Form is in a JSM project and Jira software does not support this feature today.
scherdin
Alright, thank you very much regardless.
