Audit custom fields
Sandra Carrillo
Hi!
We would like to if it is possible to audit custom fields in Jira Software.
Thanks a lot!
Nic Brough -Adaptavist-
May 25, 2022
What do you want from an "audit"?
Sandra Carrillo
Hi @Nic Brough -Adaptavist-
What we need is to be able to filter by a custom field to see when and who has changed the value of the field or can export the "Historial" (attached).
Yuliia_Borivets__SaaSJet_
Hi @Sandra Carrillo
In the case, you described I can suggest trying the Issue History for Jira app if you're ok with it.
Here you can add any standard or custom field to the grid and monitor all changes (Column manager option). Export to CSV or  XLS files is available.
The plugin is developed by my team, let me know if you have any questions.
Like • Sandra Carrillo likes this
Sandra Carrillo
Like • Yuliia_Borivets__SaaSJet_ likes this
Fabio Racobaldo _Herzum_
Hi @Sandra Carrillo ,
here a how-to guide in order to retrieve all audit activities including custom fields https://support.atlassian.com/jira-cloud-administration/docs/audit-activities-in-jira-applications/
Keep in mind taht you need JIRA Administration permission to view all these information.
Hope this helps,
Fabio
Sandra Carrillo
Hi @Fabio Racobaldo _Herzum_
Thanks for your answer. What we need is to be able to filter by a custom field to see when and who has changed the value of the field. Where you indicated, it is not possible know it.
Thanks again!
Sorry @Sandra Carrillo for the misunderstanding. At issue level, you can see who, when and what changed happens through History tab :
Sandra Carrillo
Yes but is It possible to export this information?
