Auto-close an issue in Jira cloud
Mayur Gaikwad/Tech PMO
How can I auto-close an issue after a certain time in Jira cloud. I don't want to use any plugin or app.
4 votes
Ste Wright
Hi @Mayur Gaikwad/Tech PMO
You'll be able to do this using Automation, which is native functionality within Jira.
For example, to find and close Issues with no updates within the last week, the rule might be:
  • Trigger: Scheduled
    • Run rule every = 1 days
    • Run a JQL search = check box to TRUE/CHECKED
    • JQL = updated < -7d
  • Action: Transition Issue
    • Destination Status = Done
You can customise this rule as required. If you have specific parameters you need and would like further instructions, please let us know!
Ste
This helps, thank you so much for all the help @Ste Wright
Like Ste Wright likes this
