Auto slack channel creation when a Jira ticket reaches 50% of its due date in Jira software
nasiruddin.nordin June 26, 2023
I am looking to automatically create a channel in slack from jira when the jira issue meets 50% of it's due date. Is there a way to achieve this without any 3rd party app please?
Thank you.
Harald Seyr
June 26, 2023
Hi @nasiruddin.nordin
welcome to the community!
I cannot really help on the "50% part", but others solved this by using a CRON automation rule with JQL filtering for due date approaching: Solved: How can I set an automation slack for jira when a ... (atlassian.com)
Harald
nasiruddin.nordin June 27, 2023
Hey Harald,
In terms of getting the 50% part is done. Where I am stuck is at when it reaches that point, it auto creates a slack channel. is that possible?
Harald Seyr
June 27, 2023 edited
I am not sure if ceating a slack channel is possibe, but creation a slack message should be doable, please refer to How to use Slack Messages with Automation for Jira | Automation for Jira Data Center and Server 7.0 | Atlassian Documentation
This is for DC version, but I assume the syntax can be used in Cloud also.
