I created a task from an EPIC child ticket.
I would like my custom field "quality" to retrieve the value of the #quality field from the epic. Is it possible ?
Thanks fo reply.
Thanks for reply Mikael.
I don' understand "fix versions" because my custom field is "#Qualité" and i not want to have all EPIC fields , just the custom field .
Yes, that is possible and can be done using automation. The automation would look something like this one that copies the fix version from the epic to the newly created issue if it hasn't been set already:
