Automate Custom Fields in Sub Task to Copy Value from Main Task
Swaroop Bangera
July 24, 2023 edited
Hello There,
I have a main task ticket with these 4 custom fields.
Inside these main task there are Sub tasks as well with the same custom fields.
I want to automate the fields in the sub task to take the value same as the main task automatically.
Please help me with the formula to be used in Automation
John Funk
Hi Swaroop,
Take a look at this rule in the playground to see if it helps you get your rule created. Give it a try to create it and post your rule back here if you need additional assistance.
https://www.atlassian.com/software/jira/automation-template-library/rules#/rule/1357200/25940490
