Automate URL using Set Issue Field - JMWE
RIZKY JTUASIKAL
I have 2 fields, BA Department and URL Capacity Calculation.
How do I do it,
when I select the value "IT BA Corporate Function" from the BA Department field, the value of the URL Capacity Calculation field will automatically change to "https://jira.btpn.skyfencenet.com/wiki/spaces/MI/pages/3960931426/IT+BE+Corporate+Function+-+Resource+Capacity+Calculation"
I have tried the following method, but the result is not showing
I've tried removing the "https://" but it still doesn't work
Can anyone help me?
David Fischer
May 19, 2023
Hi @RIZKY JTUASIKAL
Where did you add that post function? Are you sure it's actually running when it needs to? Did you check for errors (on the summary of the post function)?
And when you say the result is not showing, what she's it mean?
RIZKY JTUASIKAL
Hi @David Fischer ,
>> from status A to B
>> when I checked, there is no error information appeared
>> The result should appear on the View Screen (yellow highlight, under the BA Department field)
is there something wrong with my query @David Fischer ?
or is there a character missing from my query? :(
as additional information, I used a custom field (single list/choice) for the URL Capacity field:
David Fischer
May 19, 2023
Did you "test" the Nunjucks template (using the "test Nunjucks template" button) against an issue to make sure the correct value is returned?
What is the type of the BA department field? And of the url capacity calculation field?
RIZKY JTUASIKAL
>> here's the result:
BA Department field =
URL Capacity Calculation field =
David Fischer
May 19, 2023
As you can see, testing the nunjucks template against an issue returns an empty string instead of the appropriate value. This means that the values inside the case statements are probably not exactly the value selected. It could be a case issue (upper vs lower case) or a trailing space in the single-select options. To check the exact value of the BA Department field, you can test this against the issue:
*{{issue.fields["BA Department"].value}}*
and copy the value between the asterisks (including any leading/trailing spaces)
Like RIZKY JTUASIKAL likes this
RIZKY JTUASIKAL
Hi @David Fischer
sorry for the late reply,
and thank you very much for all your feedback!
Now it's working properly
