My automation rules for creating a set of tasks every Wednesday did not work, it was not even run, according to the audit log.
Could you help me figure out what I did wrong?
Is the cron accurate? Isn’t it “hour minute DOM MO DOW” ?
8 0 * * WED ... would be at 8am every Wednesday I think. Note that the time is in UTC so adjust for your TZ off UTC.
Yep, you are right, the time was not adjusted, thanks)
