Automation: Add multiply a custom field and add it like days to a date field
Facundo Castillo
Hello, I have a problem that I cannot solve. I've been looking around the community and I haven't found a solution.
I have 2 fields:
  • Numeric type: "Number Flag"
  • Date Type: "Due Date"
When a issue is created i need to edit the field "Due Date" adding days:
  • "Due Date" plusdays ( "Number Flag" * 10)
Example:
  • 05/07/2022 + (2 * 10) = 25/07/2022
Any recommendation? Thanks!!!
2 accepted
Aditya Sastry
July 14, 2022
Hi Facundo,
Please try the below syntax in Project Automation
{{issue.dueDate.plusDays(Number Flag.multiply(10))}}
Below is a screenshot of the section. I have used "Feature Ranking" a numeric field in my instance.
Facundo Castillo
Thanks for the help, i finish the problem with an hybrid with your answer and John,
Result:
{{#issue.Payment Date}}func=plusDays({{Number Flag.multiply(10)}}){{/}}
John Funk
Hi Facundo - Welcome to the Atlassian Community!
You should be able to do this with an automation rule.
When you update the Number Flag or Due Date field, you will use a syntax like this:
{{#triggerissue.duedate}}func=plusDays({{issue."Number Flag" * 10}}){{/}}
Give that a whirl and let's see what happens - hopefully I have the syntax correct.
Facundo Castillo
July 15, 2022 edited
Thanks for the help, i finish the problem with an hybrid with your answer and Aditya, because * doesnt work in this query.
Result:
Like • John Funk likes this
John Funk
Great!
Kian Stack Mumo Systems
Try to follow this documentation on math expressions. Have you already tried any of these?
