Automation: Create a recurring Task and change its workflow status
Barbara Theiß December 12, 2023
For a recurring weekly task I want to set up an automation time based rule, that creates an issue and moves it to the current sprint. This works fine but I also need to change the workflow status from "Open" to "ToDo". As soon as I add an "Transition Issue" component to my workflow I need to add jql to my trigger but I have no idea how to write an "give me the issue that this automation just created" jql statement. Any help?
David Friedrich
December 13, 2023
Hi @Barbara Theiß
This is how I'd do it:
Antonia
Hi @David Friedrich
eine Frage zu dieser Regel:
Diese Regel erstellt alle 2 Wochen einen neuen Vorgang mit dem Vorgangstyp "Task" und dieses Ticket wird dann mit dem Status "To Do" erstellt, ist das richtig?
Like David Friedrich likes this
David Friedrich
February 21, 2025
Fast. Der Vorgang wird zunächst im initialen Workflow-Status erstellt und dann in den Status "To Do" verschoben.
Like Antonia likes this
Barbara Theiß December 13, 2023
Hi @David Friedrich , thanks for the template - the branch was the thing that was missing!
Fazila Ashraf
December 13, 2023
Hi @Barbara Theiß
Can you add another automation that triggers on issue created event and looks for issues matching the condition of given recurrent issue summary and then transition it to the desired status?
Michel Neeser
December 13, 2023
Hi @Barbara Theiß
Adding JQL should not be needed for this use case. Can you share a screenshot of your rule? This will help us suggesting a suitable solution.
Register Now
