Hi All,
I dont feel this is a hard automation but I can not get it to work.
Workflow i want is on issue creation, If a user is assigned then the description will be updated to the following:
{{issue.description}}
{color:#36b37e}*Original Estimate:* Xh ({{issue.assignee.displayName}}){color}
If the issue is unassigned then it is update to:
{color:#36b37e}*Original Estimate:* Xh (Staff Member){color}
This is a prompt to enter your name and estimation once you start a job. For the life of me I can not get the automation to detect when the assignee is "Unassigned"
I also tried removing the If statement and instead using {{issue.assignee.displayName | Staff Member}} as I found in another question but his does not work either.
Thank you!
Hi @jonathank and welcome to the community!
Try the following rule, because I've tested it and works:
The problem with your rule was that even if the issue was unassigned, then the last component will be executed no mater what! Is outside of the if/else statement. So you will edit the description always.
Hahaha oh no. Thank you so much. I will go check this in the morning... What a rookie error :-/
Hopefully this will help someone else in the future!
No worries mate. It's easy to get lost in the UI if your are not familiar with. Especially if you have a long if statement with lots of actions. The line will get bigger ;)
Still shaking my head at the small text that says "Add Else" in my screenshot haha. This automation has been working great for a week now. Thanks again Alex!
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
