Automation: Help with json automation
Martin
Hi there,
I am using an automation to sync the issue summary (title) between 2 projects. I'm using the built-in automation called: Copy Summary from trigger issue
I would like however to create a custom name composed of the issue key and the summary
Key: "PS-417"
Summary: "Bla Bla Bla"
New Summary: "PS-417 Bla Bla Bla"
Why? Because we report this info to the customer portal into a Jira service desk project and since we cannot choose the field in the portal, I want the customer to know our "internal" ticket as well as it's external ticket. So we figure out to add it in the title.
I am a wannabe Jira expect but very dumb when it comes to json. I have yet been able to build one that works. Can you help me setting up the code that it needs?
Thank you!
May 4, 2022
Hi @Martin
When you note "help with JSON automation", what do you mean?  How are you making the update?
If you used an automation for Jira rule, the edit action should allow you to set the updated summary with:
{{triggerIssue.key}} {{triggerIssue.summary}}
If I am misunderstanding your request, would you please post an image of your complete automation rule to provide some context?  Thanks!
Martin
May 4, 2022 edited
Hi @Bill Sheboy , thank you for your answer.
Yes I say json because I think that's what you need to build with the custom automation code under More options.
Here is the screenshot of the automation that works for now.
Martin
@Bill Sheboy  thank you for your help, you made it work!
Can you tell me where I can find these references? thank you.
Solution:
May 5, 2022
I am glad to learn that worked for you!
Regarding references, these are spread around a bit and always improving.  Here are some good places that I use a lot:
Happy automation researching!
Like • 2 people like this
