Atlassian hast started do change the Parent Link and Epic Link field in our forms to the new Parent field:
I tried to update some of our automation rules that make heavy use of the following changelog smartvalues:
{{#changelog.epic link}}{{fromString}}{{/}}
{{#changelog.epic link}}{{toString}}{{/}}
{{#changelog.parent link}}{{fromString}}{{/}}
{{#changelog.parent link}}{{toString}}{{/}}
I changed them to
{{#changelog.parent}}{{fromString}}{{/}}
{{#changelog.parent}}{{toString}}{{/}}
But they seem to always be empty. The old names (still) seem to work.
Is the parent field called something different as a smart value, or haven't they just implemented the change yet?
Hi @flaimo
It seems those changes are still in-progress of rolling out, as described in this response from an Atlassian employee to a similar question today:
And from my experimentation...the behaviors of backward compatibility versus replacement seem different than originally described for the sunset of those epic fields. For example, I just tested with the REST API function to check for supported automation fields and "Epic Link" was empty for me and parent was not.
I recommend watching for updates in the community articles and here to note changes:
https://confluence.atlassian.com/cloud/blog
Read the story
