Automation: Release is approved.
David McCorkindale
November 9, 2023
I'm trying to figure out if there is any automation options to release a version when it becomes approved?  The approval condition in the automation only says it works for jira service management?
It would be good to be able to initiate the release upon approval.
November 10, 2023
Hi @David McCorkindale
While there is no automation rule trigger for approving a release, and the Version Updated  trigger does not detect approval changes...there is a work-around: use a scheduled trigger and call a REST API function to check approvals.
For example:
  • trigger: scheduled trigger rule
  • the fuzzy part...decide which versions to check, or check them all
  • action: Send Web Request to call a REST API function to get the information (please links below)
  • advanced compare condition: check if your version is approved by all approvers
  • action: release version
Regarding the fuzzy part, to use a specific version, you could use Lookup Issues with JQL to find the issues in the next, unreleased version...and then use that in a call to the REST API.  This seems a better idea than...Or, you could gather all of the versions and parse / filter them.  That may be a problem later as more versions are added, pagination or filtering is required to get your correct version.
When making the REST API call, add the following to the end of the URL so the approver information is returned:
?expand=approvers
If you want to try this approach, here are some references:
How-to article for calling the Jira REST API from a rule -- https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Get a specific version -- https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-project-versions/#api-rest-api-3-version-id-get
Get all versions, paginated -- https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-project-versions/#api-rest-api-3-project-projectidorkey-version-get
Valerie Knapp
Hi @David McCorkindale , thanks for your question.
You could try, as a workaround, if you use an issue in Jira to record when the Release is approved, on the transition to the status to 'Approved' to release the version, like this
The default behaviour of the rule is to release the next unreleased version but it should be possible, if you have the FixVersion in the Jira issue, to refer to that with a smart value.
Please evalaute this solution and give us your feedback.
Cheers
