Hi All,
Currently the scope options for Automation Rules in Jira is:
If you have multiple rules that you want to run for a subset of projects then these options don't really work well.
Currently I use Multiple Projects and add the project to every rule every time we create a project in our team, but this is a pain.
Single project obviously won't work. I don't want the rules applied to all projects and project type is too coarse in granularity and doesn't map directly to the relevant subset of projects that I want to use.
What will work is using project category, as I can set up a project category and use this category for my set of projects. Unfortunately, project category is not available when setting the scope option for automation rules.
So my questions:
Thanks in advance
MA
This is a useful suggestion. You might wish to use the in-app feedback link to share your thoughts with Atlassian. This forum isn’t the best means of connecting with the Atlassian product owners.
Hi @MA
Yes, and...to what @Jack Brickey notes: here are the suggestions to add that feature for category scoping:
For work-arounds...
Best regards,
Thanks @Jack Brickey & @Bill Sheboy . I have added my experiences to the Jira issue you advised in your post. Hopefully the suggestion/request will gain traction with Atlassian in the near future.
I have similar problem with automation fired on events, especially issue created event. As my projects use all the same workflows, I'm going to change event to custom and start rule with this event instead of issue created. I'm testing this approach.
