Automation Rule stuck in progress
Mahima Srivastav
June 30, 2021 edited
One of my Automation rules has been stuck in-progress for quite some time now.
Is there a manual way to stop the in progress automation?
Sadeesh Narendran
June 30, 2021
@Mahima Srivastav Did u try disabling the Automation?
Mahima Srivastav
I did. But that didn't help. I guess for some reason it was stuck in a loop and resolved itself.
Sadeesh Narendran
June 30, 2021
Check the Audit logs for details!
Mahima Srivastav
I did. Somehow it didn't show any signs of delay. Probably a one-time bug
John Funk
Hi Mahima,
Unfortunately, you can't stop the automation manually once it gets started. It will eventually run it's course and error out due to a loop or will get throttled.
The Audit Log should give you some details as to the problem.
John Funk
Is it working for you now?
Register now
