Automation Rule
antony.nelson June 10, 2020
How do I define a rule that gives an output of available issues on a sprint within a single message rather as a a separate message for each issue on MS Teams. I want all as a list within a single MS Teams message.
2 accepted
michael sam August 3, 2020
Does Jira administrator need to enable automation rules when creating a project?
or is the rule automation part of projects when created and rules can set by the project administrator?
Radhika Sajin
August 12, 2020
Hi Michael
Global administrators can always manage rules.
Go to System- Automation rules- You can get the option for global configuration for Automation
If you want to allow project managers to do the automation, please check the option "Allow Project administrators to manage project rules" and ad their group in the available option
Please let me know if you need more information
Radhika
John Funk
antony.nelson June 14, 2020
Thank you so much, It worked. However, the Issue type parameter (both either type or type name) is not picking up despite being tried in different ways. The rest of the issue fields are being supported. I can live with that for now anyway.
John Funk
Great! Glad it is working for you! Can you share your rule so I can understand the type part better?
My Message format
Content:
<ul>
{{#lookupIssues}}
<li>{{key}} - {{issueType.name}} - {{status.name}} - {{summary}} - {{assignee.displayName}}</li>
</ul>
{{issueType.name}} --- This doesn't come up
It comes with Blank hyphen something like below.
Content:
A-1 - - In progress - Story Summary -  Antony
B-2 - - In Testing - Bug Summary - Nelson
My Filter JQL:
issuetype in (Bug, Epic, Feature, Spike, Story, Task, Sub-task) AND project in (A, B, C) AND Sprint in (1, 2, 3) order by issuetype, created DESC
John Funk
Awesome job - way to go!! And thanks for sharing!
Radhika Sajin
August 12, 2020
Good article, very informative
Jerome Ortega March 22, 2021
@antony.nelson did you ever find a workaround for the empty issueType.name?
antony.nelson March 22, 2021
Unfortunately, No, I haven't found one yet @jeromeortega
John Funk
Hi @Jerome Ortega and @antony.nelson
Try it without the uppercase T, so {{issuetype.name}}
