I'd like to create a automation to send email (single email) with the sprint scope (issues completed, not completed, etc) to certain users.
I have visited the topic bellow but still coudn't do it.
https://community.atlassian.com/t5/Jira-Software-questions/How-can-I-use-Automation-to-communicate-the-Sprint-scope/qaq-p/1331103
I have two problems:
> I need to send a single email (the automation is sending a email for each issue in the sprint).
> I need to make an email body with the sprint issues.
Help, pleasee!!
Hello @Pedro Webster ,
Welcome to the community.
I found several posts on sending a single email with a list of issues via Automation. Perhaps one of those would help.
The answer from @Bill Sheboy in this post seems like it might be useful in your situation.
Hi @Pedro Webster -- Welcome to the Atlassian Community!
Adding to Trudy's answer, the key helper for your use case is the Lookup Issues action to gather issues for one email: https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Lookup-issues
Hello, @Trudy Claspill and @Bill Sheboy
Thanks so much for the answers !!
The challenge now is making a JQL that shows issues of my previous sprint.
The JQL query "project = myproject AND Sprint in openSprints()" doen'st work because my trigger is When: Sprint completed, so it returns blank =(
Any tips? tks again!
Use the sprint smart value in your JQL
sprint = {{ sprint }}
That should pull the sprint that triggered the rule.
References:
You might need to add quotes around the smart value in the JQL.
sprint = '{{sprint}}'
You can also try using a Log action to confirm that the smart value {{ sprint }} has the value you would expect from the closed sprint.
https://support.atlassian.com/cloud-automation/docs/debug-an-automation-rule/
Register today!Online forums and learning are now in one easy-to-use experience.
