I am looking for a suitable trigger to use that will check all sub-task status and then transition the parent status based on a result.
eg: If any subtask status = REJECT, transition parent status to FAILED
I tried a scheduling trigger but that resulted in an error;
Can't branch rule as it requires issue(s) in the context for this option. More than likely you have a trigger that doesn't insert issues into the rule chain. e.g. Scheduled rule not running a JQL query. Creating an issue does not put an issue into the context, you have to branch on it directly.
Outside of the above, I don't see a suitable trigger for a workflow based on a subtask event.
Hi Mark - Welcome to the Atlassian Community!
What if you used Automation For Jira and created a rule for when a Sub-task transitions to Reject that you then auto-transition the Parent to Failed?
Hey John..... you know.. I was in a rabbit hole there.
Thank you!
Is this an extension ? Can you help me with that I have the same issue(
Hi @Astghik Sargsyan - No it is a free tool and part of Jira Cloud. Here is some more information:
There are two types of automation:
Automation Basics: https://www.atlassian.com/software/jira/guides/expand-jira/automation
You can do this via global rules to apply to all projects also. You'll need to be a Jira Admin/Site Admin, go to Jira Settings > System > Automation Rules (left-hand menu).
For more on using Automation For Jira see these help pages.
